3D custom rotation
Command |
Path |
Rotate 3D |
Modify > Rotate |
The precision of the rotation values that can be entered (degrees, minutes, and/or seconds) depends on the Units setting.
To rotate at custom angles in 3D:
Select the 3D object or objects to rotate.
Select the command.
The Rotate Object in 3D dialog box opens. Specify the rotation parameters.
Parameter |
Description |
Rotation Angle |
Enter the angle of rotation |
Center of Rotation |
Specify the desired center of rotation: Working Plane Center Object Center Next Mouse Click |
Rotation Axis |
Select whether the rotation axis will be based on the Active Layer Plane or the Working Plane, and whether to use the X, Y, or Z axis |
